View unanswered posts | View active topics It is currently 29 Oct 2026, 13:21
 [ 6 posts ]
 Post subject: Update to Imbuing Calculator
PostPosted: 03 Feb 2013, 22:04
Greetings All
We have been coding this weekend, and solved bugs (hopefully) as well as added one new feature.
Bugs Solved
The following bugs should now be solved:
  • Mage armor should no longer be selectable on medable armor pieces
  • Velocity should no longer be selectable on throwing weapons
  • Mana and life leech should now be calculated correctly for ranged weapons
  • Whetstone toggle should now work as intended
Project Saving
We have added the ability to save projects from the imbuing calculator in our database. This will be fetchable in multiple ways.
  • Not logged in via Imbuing Projects using an ID tag, provided by someone who have saved a project in the database
  • Logged in via Imbuing Projects will provide you with a list of all the projects you have saved and options to fetch them with a link
  • Via direct URL to a project, simply by copying the adress from your browser.
To note is that users are required to be logged in, to be able to save projects, but not to fetch them.
To get started head to the Imbuing Calculator by clicking below button.
 Post subject: Re: Update to Imbuing Calculator
PostPosted: 08 Feb 2013, 17:21
05 Nov 2010
Formosa
Thank you very much.
PostPosted: 08 Feb 2013, 17:28
You are welcome! ;) Do let us know of any feedback or bugs you may find!
PostPosted: 13 Feb 2013, 21:48
Fixed so that hitting enter in the comment field saves the project.
Fixed a typo in the link back to imbuing calculator after submitting a project, thus should no longer give a 404 error.
PostPosted: 15 Feb 2013, 04:32
The time of which Projects has been saved should now display in your local timezone, You can edit your timezone in the UCP.
PostPosted: 26 Feb 2013, 17:07
Fixed links, for Internet Explorer, on imbuing calc to:
  • Fetch a project with an ID (If not logged in)
  • Saved Projects (If logged in)
Both cases wrongfully directed to a 404 error, and should now both correctly direct to http://www.knuckleheads.dk/tools/projects in any and all browsers.
Sorry about that..
 [ 6 posts ]
Users browsing this forum: No registered users and 1 guest
[ Time : 0.128s | 16 Queries | GZIP : On ]
